Hey all, this is my first post here. I own a 03 Sonoma SLS ext cab. The two seats in the front, and the jump seat in the back. I have read on older posts but the answer is not really clear. Can I (A) put a bench in the front, and if so what are ones that I can just slide in without having to **** with the floors and making new frames and what not, or (B) add a seat somehow to the back?
· time to get cereal
Extended cabs came with 60/40 bench seats. Unless someone swapped for buckets, you have 3 seats in front already.
· Premium Member
IIRC, the mounting for the (GM) split bench is compatible w/ the (GM) bucket seat mounting; you should be OK w/ a 60/40 seat from a 2nd gen ('98-'03) S series body. Here's a link to seat swapping that may help: Search results for query: swap 60/40 bench for bucket seats
With the split bench, that should make for 3 in the front, and the 4th in the rear jump seat.
