101 - 120 of 131 Posts
· Bowtie Supply, RIP
I recently had someone swear up & down his 3KCD behind his 4.8L is a 4l65e. He even blocked me because I said 3KCD is a 60e not 65e...
· Been there Done it
He probably swears it came behind the power house 4.8.
You're better off blocked.
2003 Tag ID Vehicle
3CAD 4.3L C-Truck Standard cab, G-Van
3CBD 4.3L C-Truck Extended cab, G-Van
3CHD 4.8L, 5.3L G-Van, C-Truck Standard cab
3CJD 4.8L, 5.3L G-Van, C-Truck Extended cab
3KAD 4.3L K-Truck
3KCD 5.3L K-Truck, H-Van
3KZD 6.0L K-Truck 4L65E Most were 4l80E
3MSD 4.3L M-Van
3SAD 2.2L S-Truck
3SCD 4.3L S-Truck
3SDD 4.2L S-Truck
3SHD 4.3L S-Truck
3TAD 4.3L T-Truck, L-Van
3TDD 4.2L T-Truck
3YDD 5.7L Corvette
Everybody should find his ad and click the More Options button and Report Seller and select the Scam button...
Where was it listed for sale? Hopefully not on FBMP. That's scam city.
Yep! That's where it was. He got offended I told him it was a 4l60e and spewed a generalized insult like "I'm tired of dealing with you idiots who don't know nothing!" or something like that. Then he replied back that someone bought it. Then I saw it for sale the next day & reported him...
· Premium Member
2002 blazer xtreme
I finally found a 4L65e from a reliable licence shop but is 4hrs a way and he wants $500. plus $150 core. The shop went through the transmission cleaned it up put new filter, pan gasket and replace the front and rear seals. with a 30day warranty I would like some advise on this. I can find used 4L60e for around $400-$600 locally with no warranty. Rebuilt runs around $800 plus core from a small shop.
· Randy
Discussion Starter · #111 ·
Tag is 6KCD
6KCD is not a 4L65E. Just an LS based 4L60E Thats were people get confused. You cannot tell the difference between them sitting next to each other. The tag tells you M30 or M32 RPO codes.
Reactions: theoriginalbowtie
I'd bet on FBMP there are 3 times as many 4L65E's sold as were ever built. Weren't 90%+ 4wd? Which means a complete teardown if you want it in a 2wd. So why not just use a 2wd 4l60E and add the few parts while it's apart.
· Premium Member
2002 blazer xtreme
So 5KCD is wrong also. I do not see a 4SSD,7HBD, 8HBD,9HBD, 9HED on the PDF.
What I have found is the transmission shop I have been talking to also do not have a clue . @oldeerslayer your right I should just get a local reputable trans shop to build a 4L60e transmission with good parts. One guy recommended that I install Zpak, wide band and a transgo upgrade. Price was an adder of $100 to the $795 price tag. Truck will probably not see the track. I wanted to be able to DD this. I will add a trans-cooler for sure.
Thanks for the PDF
How do we get codes from ATRA? Anybody know? Their site isn't exactly user friendly... maybe if you're a trade member.
· Randy
Discussion Starter · #116 ·
you would have to be a member and attend the training seminars. the information on my PDF file is not complete. I have been looking for information to complete it for 5-6 years... Nobody wants to share 2006-2014 transmission codes to make/model/engine.
· Randy
Discussion Starter · #117 ·
From the first page
6KCD is listed
i would have to give ATRA the benefit of the doubt then. Typically the KCD units in the past have been 4 pinion planets. I know I have torn down a 5KCD and I cant remember if it was 4 or 5 pinions planets. I'm going to make a post on it from another site and post back if I get anything
· Randy
Discussion Starter · #118 ·
From the first page
6KCD is listed
I reviewed my list that I have and and 5KCD, 6KCD are for 5.3L engines and are not supposed to be listed in that, my mistake. The original post has been corrected and 5KCD, 6KCD have been removed
