1 - 1 of 1 Posts
98onyxsonomazq8
well I figured out why my trans wouldn't shift out of second gear properly. It had nothing to do with the trans!!!Went to a trans shop it had no codes, the engine did not either. He told me the trans was doing exactly what it was supposed to do, what it was programmed to do. Which leads to the hypertech programmer. I put my stock programming in, then I put in what i wanted, and this time i only programmed it for the gears I have and the top speed. So I think what the programmer did was when i took the increased shift points out, it decided that second gear would remain the same. And was finally fixed by putting stock back in and starting it over. Now it might have something to do with shift firmness also, since i didn't put that back in. But anyhow, the transmission shifts where it is intended now.
I know there was another memeber on this board that had the same problem, I hope you see this post. Please reply if it cures the problem, then maybe it should be a unforunate sticky.
1 - 1 of 1 Posts
