Im installing this 4 link from sd.
What setup can i do to get max lift, while using this 4 link.
and if anyone has pics of their BOA lift post em up
Afterhours Admin
run a large sleeve bag or a 8" double convoluted bag and the ride will be fine, and get you 9+ of lift. if you switch to bags on the bar, you will need another kit.
NICE WELDS MAKE ME =)
re8's over axle arent bad, but they dont compare to bag on bar setups ive seen. i have the same link setup you have pics of, installed on my dime with re8's over axle. i am 100% satisfied with the link setup but if i could go back i probably would have went bag on bar, just because when i am at full lift all the way around my rear is alot lower than my front and im runnin re6's in front. i just think it would look better if i could lift my truck and have it sit level front to back. also over axle rides real hard on shitty roads, i still havent had time to get my rear shock setup done and i am payin the price now because the rear shook so violent it shook my comp loose, snapped the leader hose and bounced across the road like a maimed squirrel. im sure it will ride a hell of alot better with shocks at least i hope.
