Just got my 4 link and going to mock it up. Wondering if anyone has any tips they would like to share for it is my first 4 link install. And the notch do I center it at stock ride hight or where I want my normal ride hight at? With driveshaft hooked up axel moved forward about a inch from stock hight with leafs in? Any input would be greatly appreciated before I start welding.tia
Wood Line Composite material Gas Automotive tire
Bicycle tire Automotive tire Wood Twig Line
Axle touching the frame is typical average bagged ride height setup, tack the axle there with the old u joints and mock up four link, then do notch. U cut the rear of the leaf springs off so that’s probably messing with the front to back measurements a bit, so to be super sure, take some measurements to make sure u have it in the right spot. Here’s a picture link. It’s a nfamus kit but the idea is really the same.
Question here how do I find the proper pinion angle without the motor in? Do I set the upper adjustable bars in the middle so I can fine tune it later?driveshaft is at 2 degrees from the carrier to the rear end and axel is at 4 degrees. Lowers are tacked in.non adjustable
Wheel Automotive tire Tire Motor vehicle Tread
