just added 4" blocks and pulled a leaf on my 94 s10 and wow that lean shows more n more the more you lower it, i measured and the left side is an inch lower than the right(bad lean right there) and i determined this by measuring the back lip over wheels, so im thinking maybe i could put one of the 3" blocks i have bak on the left side and that should pull it up to level with the right side i think....also im bottomoing out on bumpstops like crazy and i want to notch now, what notch should i use? and where should i buy it, i want a good one for cheap preferably....thanx
