1 - 13 of 13 Posts
I have a 92 Sonoma GT that I want to put a v8 in. At my local junkyard there is a 4.6l northstar v8 out of a 2006 cadillac srx. Ive done a little research and from what I've been able to tell there are no manual options for this engine setup? The engine itself would be $450 to pull from the junkyard. Has anyone done this swap? My big question is how do I pair a manual RWD tranny to the engine. I saw someone say something that a s10 bellhousing has the same bolt pattern and would then open up transmission options?
· Premium Member
Even cadillacs didn't like having the North Star engine in them. They love to pop headgaskets
For 450.00 you can have a 5.3 out of a truck which will be 10x easier to get in and function
As long as you go with a LH2 you’ll be fine, you won’t have to worry about head gaskets, and it’s a RWD platform. Plus it’s 320hp 315lb ft from the factory, there used to be an outfit out of Canada that could tune your PCM/ECM and get more out of them. They did a number on my STS and really woke her up, not that it was a slouch to begin with…removed the speed limiter as well. They used to be quite active on the Cadillac forum so you could check out there, or their website Northstar Performance - Cadillac Head Studs, Cadillac Head Gasket Repair, Northstar Engine Repair
· Premium Member
I have an '05 STS in my yard right now. I have Mack and Detroit trucks in our fleet that don't leak as many fluids that the STS does. I did the head bolt inserts in a '99. My one and only time and the last. You can get a factory supercharger for the Northstar pretty cheap off ebay from an XLR-V. I personally would not go for this swap as it isn't a popular swap but maybe a Cadi forum could help more.
1 - 13 of 13 Posts
