1 - 2 of 2 Posts
bagged after winter
Sometime down the road i want to change out my motor. I was thinking a 4.3L built up to take a 100 shot of NOS, w/all the 4.3L bolt ons, and if the make it...the ZZ4.3L intake.
But i've been told a 350 would be just as easy w/more power w/less bolt ons.
and the trans will bolt up to both? wierd.
let me know what ya think
thanx
2 Litre Terror
First, the stock motor will take a 100 shot no problem as long as you use premium gas and drop the temp range on the plugs about 2 steps. Run premium fuel and you should be okay. Nitrous when used wrong is the number one reason motors toast. As far as the swap goes, yeah a 350 is sweet. but you have to raise the questions of. how much do I drive it. Is it my daily driver. A small block midly worked will run ya about 2500 - 3000. plus any extras you need for the swap. In the end though its all a matter of choice. Hope this helped
1 - 2 of 2 Posts
