Hi Folks
35 years with engines and you had your fair share of troubles, rod bearings knocks, pistons out through the block, cracked blocks, valves breaking you name it, but never a engine siezing when you stop for a pee break. Slowed down and as I come to halt slipping on mud, the engine dies, not thinking of that I rush to do my stuff to clime back to start it to continue my journey. Click nothing, it doesn't crank, checking electric, belt, etc then trying to turn it my socket on the harmonic balancer, it doesn't turn, removed inspeciton cover a bit tried to turn it, rock solid stuck. Yes hell to come back as over 3h from home but that is a different story.
There was no issue prior, no overheating, no power loss, no shudder no nothing, just towing a empty trailer on a country road pretty uneventfully until I needed to stop. It was about a 1/2 quart low on oil, but that is the only thing really wrong. Just don't get why. My idea is to remove dizzy and turn the oilpump with a drill to force oil though the system and then see if it comes loose. My question is just why did it happen what could trigger it, as I've never experienced anything remotely like it.
Cheers J
Cheers J
