1 - 10 of 10 Posts
on my 92 blazer 4.3 CPI i have had a full tune-up on it, changed wires,plugs,coil,distributor,fuel filter,air filter, and i have ran numerous amounts of fuel treatment/injector cleaner thou it. it has 215,000 on it and the lady i bought it from let it sit in the backyard for 2 years. the problem I'm having is it has a rough idle shakes the interior etc, and a popping from the exhaust pipe, also if you let it set and idle for to long when you take off his has a hesitation to it but having flouring the gas pedal it clears up and takes off.
can anyone tell me what might be wrong?
Discussion Starter #2
1 last thing i was getting a code 45 would an o2 sensor be causing all these problems?
Clean N' Dark
Could be a faulty O2 sensor.
I think your CPI might be shot.
spark plugs are all right. how much its the cpi and where can i buy it online and how hard is it to replace
it could still be your O2 sensor, Code 45 is a Rich O2 reading, so its obvious the computer is dumping in lots of fuel cause the computer doesnt understand what the hell is going on.
Sensors are about $45 which is going to be a lot cheaper than a CPI unit. If you have a friend in the area with 90-93 S-Series 4.3L, try swapping sensors and see if that does it before blowing $45. I think it requires a 7/8" wrench.
FactorY RolliN
mine does that tooo it sat for a couple of months out in the weather... but i havent tuned it up yet it only has 108k still starts good and runs good though just idles hard
Kramerica Industries
Take your plenum off and look at the CPI unit, if one side looks 'clean' that usually indicates a fuel leak on that side.
A leaky CPI could cause all the symptoms you are describing, and would be putting so much gas into the engine the O2 would probably get a rich reading.
1 - 10 of 10 Posts
