Not much. Doing plugs and wires and distributor tomorrowWhat have you done so far?
2 and 4Start by scanning it to see which cylinders are misfiring.
Was wondering why own?? Just changed mine on 97 S10 4.3 and haven't had a problem yet..do you think I will? And should I change to own?Plugs & wires should be oem....or you'll be sorry....
OEM...Was wondering why own?? Just changed mine on 97 S10 4.3 and haven't had a problem yet..do you think I will? And should I change to own?
Thank you...that makes sense..The General spent a lot of money making the ignition system reliable...why mess with success... A lot of aftermarket components, especially plugs, caps, and rotors don't do well. Use what you have un til they fail..then go OEM.
I always go oem when possible. Just seem to be better quality and last longerWas wondering why own?? Just changed mine on 97 S10 4.3 and haven't had a problem yet..do you think I will? And should I change to own?
For those wondering. Mine ended up being the whole distributor. I did a new distributor with OEM cap and rotor. Went back with new OEM plugs and new wires as well2003 4.3 vortec
Misfire issues
Not bad at idle worse around 1000-1200rpm then smooths out some from there up.
I just want to know where to start with fixing it.
