no one is doubting him or calling him a novice... its a tricky 20 yr old fuel system and one little 20 yr old wire can knock the whole thing out. its easy to test power and ground. static pressure tells you virtually nothing in this case. it should not be overlooked.
thats the thing, the delco pumps and the name brand pumps use a squarish 4 prong connector which matches the oem....they are plug n play, but they are grossly overpriced.
the chinese pumps, of which there are hundreds of different no-name-fly-by-night 'brands' for the exact same pump, all use a flat 4 prong connector that is not oem. he said he had to rewire, so he used a cheap no-name pump from china, not a name brand pump.
theres no better or more accurate way to describe these parts other than 'china'... amazon, ebay, aliexpress, rock auto, and every part store has copies of the same pump each with a different brand name, each brand name with zero brand recognition. some listings even reference multiple 'brand names' for the same part...
theres literally no way to 'construe' that as 'racism' or whatever...
