1 - 16 of 16 Posts
choppin on twankies!
the side wall isnt goin to be that small on a 255-35 the side wall is 3.5" and on that tire its 4.3" what are u puttin that big wheel on damn!! its goin to look sik!
if you looking for it to be wider so you can get grip with the LS1, with either a locked rear end or a good limited slip a 10" rim should be fine, unless you build the engine up or have a power adder then I'd get the 12"
when I was gonna drop in a LS1 I was gonna go with 10" rim..
your truck is badass man.
that a static drop? how low?
the 315 is gonna be really huge under there and i doubt you will get a properly spaces 12" rim... 10 is pretty much as wide as you can go tho tire width has seen 335's under some
Hey intro! I want 20's on my 03 Crew Cab, but it's 4 wheel drive, so the front wheels stick out more. Can Intro take care of that with backspacing? I already had ya'll in mind.
NuLowz Customs
I had 315 nitto drag radials on my camaro they were on 17x10, they ought to fit a 12" though...
well if u get a narrowed rearend then ull have to back half the frame cuz the frame sits flush with the factory inner fenders..just my .02
1 - 16 of 16 Posts
