1 - 2 of 2 Posts
For now, my truck is at his stock height, i'm planning to put boyd haze 18*8 in front and 18*10 in back.
Have you ever view a set of haze install on a truck, and so how does it look ???
Planning to go at 315/35/18 in back so wich backspacing did i need ? (will a 5.5 fit)
For front wich size to choose 245/4?/18 ou 255,,, ?
What king of dropping can i do with this king of tire ?
ive done one truck with a 315 35 18 at work had a 6 inch drop in back and man was it close
he had to cut the fenderlips, and on the inside bang the inner fenderwell in a little but it fit.
he had a 18x11 though.
im sure a 18x10 will be fine.
5.5 bs should be ok but id test fit the rim before you get it. i have 18x9.5 with 5.825 bs and it still fine.
1 - 2 of 2 Posts
