1 - 14 of 14 Posts
Maybe some of you can help me out im new to the whole v8 swap. First I understand how im going to put the motor in and so forth. My problem is I want to really build it up and get like over 300 horsepower out of it. Is this possible and would it cost me alot of money. I know your all gonna say get a 350 yes I would love to get a 350 but I dont think no one want to buy this 305 off me. Its an excellent motor ran great when I pulled it out of the vehicle came out of my 1987 grand prix. Heres the casting number 14093627 87-91 305 Roller cam one-piece rear seal . Can you people help me or help me sell this in order to get rid of it. Thanks
footbraker
It would cost you more to get 300hp out of that engine than it would to buy a 350 and do the same. The heads on that motor are junk above 4500 rpm.
Yeah im trying to get rid of it. You think someone would buy it for 600. Its only has a little over 60,000 on it and come with everything for the swap except a radiator and motor mounts. Also would you happen to no anyone that has an older 327 for sale.
footbraker
350's dime a dozen around here, 327 not so common. You could always put the 305 in until you get a different long block. Extra work though (changing motor twice). Either way dont waste time trying to build up that 305.
I got my 305 with 80xxx miles for $125 with a good 700R4. It was out of a '92 Camaro RS, I didn't use it in the Jimmy though, I dropped it into my 2.8L Firebird. Anyway, I doubt you will get much for that 305 unless someone blows an engine and is looking for a direct replacement.
Project: Sabriel
ebay. people buy ANYTHING on there. you can build a 305 decently; however, a 350 would be a much better investment, even if you leave the 305 alone and save the mod money and spend it on a 350. you can go Chevy 302, 327, 350, 383 with a 350 block, i think. there is also a MASSIVE 350 aftermarket industry.
footbraker
Problem with the 305 is the small bore limits valve size and therefore breathing/RPM potential. Combined with the smaller displacement and it becomes the special olympics of V8's. You can spend $1300+ on a set of milled AFR heads and only see 330 hp without power adders. My stock, used, '76 350 with a mild(267 adv.) cam and intake makes around 300 hp and I have less than $500 in the motor.
yea man Rhansen is right you can spend a ton of money on a 305 & only get small rewards {ie: horsepower & torque} if you spend the same amount on a 350 or small block 400 you can get great results. You can buy a 350 at a salvage yard cheap. Even cheaper if you pull it yourself. Also cheap local ads.
If you find a junk car with low miles that would be a start. Take some tools,wire ,remote starter button & some gas . That way you can hot wire the engine & start it to see what it sounds like. If the yard will not let you do that then just check the oil for water & stuff like that. If you have any doubts then you have to disassembe the engine & have a good machine shop check it for you.
1 - 14 of 14 Posts
