I am in the process of switching to the Dakota Digital gauges so nothing is hooked up. So to answer, gauges were working before but nothing is hooked up to those ends(gauges at least) right now.Do you have a reason got think there is a short? Are the devices on those circuits working properly?
Tried it and still BEEPs on all 3. Great suggestion.. Thanks!possibel youre seeing a side o the ing coil that gets grounded. been a while but coils are inducers and theyre grounded. try unpluging coil to verify this theory
try removing the backup fuse then check for beep. if no beep could be your neutral safety or backup light switch. check for beep on the switch side of fuse connector with fuse removed. if it beeps then you know problem is on that side of fuse.Tried it and still BEEPs on all 3. Great suggestion.. Thanks!
