1 - 12 of 12 Posts
I have replaced the entire front end of this truck, all ball joints/upper control arms, sway bar end links, inner/outer tie-rod ends and connector.
After about 3 days of driving, an alignment, normal stuff, I started hearing a slight rattling and turning felt off when turning the wheel to the left. Heard a slight squeel too, so thought maybe the brake pad clip had gotten damaged somehow. I jacked up passenger side, just out of habit I wiggled the tire and it moved. This is not good. I removed the tire, discovered that one of the 3 bolts is now missing. I have to drive on a lot of dirt roads to get to and from work/home. My problem is, this is my only vehicle. I don't have another to take one of the other bolts out and go looking for one to match. I need to know what size so I can go get some and replace all 3 of them with new ones.
Please help!!!
Oh, 2002 S10 4WD with 4.3 v6. I don't know if it is a zr/zt or whatever the other available options are.
· Been there Done it
That's the 1.5 part.
from the Bolt Depot
The thread pitch is the distance between threads expressed in millimeters (measured along the length of the fastener). For example a thread pitch of 1.5 means that the distance between one thread and the next is 1.5mm.
10mm is the diameter and 30 is the length
Maybe that's why they loosened up? Possibly not the corrected hardened bolts that GM used. If mine were coming unscrewed I'd buy 3 GM ones even if the price is a bit steep for peace of mind and then torque them to the correct spec with some blue Loctite on the threads.
1 - 12 of 12 Posts
