does anyone have any ideas on what you do about the longer oil pickup for the 4X4 oil pan? The 3.4 has a bigger tube with a shorter length and pick up on the 2.8 is smaller than the one on the 3.4.
yes, go to napa and order a pick up tube for 4.3 4x4. this is a 3/4 inch pick up tube that will fit your camaro oil pump. your 2.8 is a 5/8 tube that won't work.
I used an adhesive called locktite retaining compound available at industrial suppliers to help secure it to plate.
good luck
sam
what year 4.3 L motor.
an '89 4.3 4x4 oil pickup should work. they will have the size of the tube and it will be 3/4. be sure and tell them its for a 4x4.
again
good luck
sam
