1 - 12 of 12 Posts
I have a 3 4 drop springs and blocks on an xtreme. it bounces around like crazy. The front bottems out over bumps. If i did a 2 3 drop with springs and blocks whould that be better. I really need some advice Thank you
Boards don't hit back
If you want the best ride you should get 2" drop spindles and a 1" drop coil spring for the front and a set of 3" drop leaf springs and a 1" block for the rear along with new shocks all around. It will be more expensive than just coils and blocks but for the ride quality it's worth it in my opinion.
Useless posting member
Do you have the factory xtreme coils, or did you replace them? How big of a block are you running?
Did you cut your bump stops off?
i did cut the bump stops out in the front on the bottom it there any on the top? also its a coils waas replaced 3 in lowerin ones. shock are ones from when the truck was made.
is dekitted...
There's the problem. You need drop shocks up front with drop coils.
1 - 12 of 12 Posts
