1 - 10 of 10 Posts
So I dropped my last S10 that had 20s on it with a 3/4 and it was two low and rubbed so I had to change it to a 2/3. My question is has anyone ever done a 4/5 drop and used air shocks so they can raise it up a little when they need to drive so it doesn't rub?
Low is a Lifestyle
You can use airshocks in the back, but I don't believe that there are airshocks that will fit the front suspension. If you wanna run a 4/5 with big wheels your gonna have to remove the wheel wells and roll the fenders.
RaNdOm UsEr
i have a 3/4 drop,, my tires are 235/30/20 and i rub on hard turns,, i guess thats due to my wheel offset i suppose
mconversion I have a hard time believing that unless you took out your wheel wells.
Wicked. What lowering components did you use?
I was thinking of doing a 3/4 drop on my s10 but leaving the wheels stock for now until i get money for rims and tires, at a 3/4 drop would i need to notch or adjust pinion angle at all?
1 - 10 of 10 Posts
