Status
Not open for further replies.
So I am almost done rebuilding the 2se carburetor from my 85 2.8 and have a replacement ere, but is it needed in southern Arizona? During the winters, it may get down to 28 for a couple days at most, but average is about 35. The truck will mostly be in the garage, where its not too cold.
What say you?
Not really, no. More applicable in areas of some real cold temps.
I have the same question. What qualifies as low temperatures? Here in Victoria, BC, the temperature rarely drops below 0 degrees C.
Also, if the efe heater gasket is removed, the idle mixture will have to be adjusted, right?
It's "Neanderthal"
Mine malfunctioned (melted) so I took it completely out, and the truck ran better than ever. You won't have adjust anything.
Awww..you ain't got shit!
Funny you say that. When my truck had the Rochester still on it, when I removed the carb, it just crumbled and fell apart. Put a regular gasket on it and never had a problem (besides the carb being junk). :D
Where in Arizona? I'm in Kingman and just did the same thing. Took out efe after carb rebuild. Unfortunately I'm not sure if I did it right. Truck won't start. Just puffs and pops when I crank it
the new guy
that sounds like the timing is not right, or the spark plug wires are not in the right spots. I know this from plenty of experience in not putting them back properly
Dead threads should be left to rest in peace...
Closed
Status
