Can you guys walk me through everything I would need to buy / have done For my 2000 4.3vto be cammed? Specifically this cam COMP Cams 56-422-8: Magnum Hydraulic Roller Camshaft Chevy 4.3L V6 1992-Present Lift: .500"/.500" | JEGS
I’m aware I would need to get my heads machined like my valves ported or soemthing and I Will need stronger valve springs and Longer lifters and rockers. I have no idea the measurements or sizes I would need for everything to work properly. If you can please point me in the right direction or give me a list of what I would need that would be amazing cuz I have tried to search everything and I can’t come up with much I don’t think im searching it right
Moved to 262/4.3.
I finally got blown
F that. Get a comp 270ahr. Do a search. Someone lists part numbers for locks and retainers from comp. You will need ls valve springs. A tune will net you more power w the cam.
