Obsess about part numbers much???:blaugh:SlammedDime said:I wish I could go into every single post on every single board and change 2500 and 2600 to 255c and 224c
How so?railn20s said:I am running 2600 up front and 2500 in the rear, becasue you need the 2600 in the front if your tukn20's so you can get enough lift
Depending on the cups, you may need to trim to lay on the 20s, and will lose some lift.Southern said:How so?
2500s and 2600s both max out the front suspension
That without dropped spindles? Mine don't lift no 10 inchescab said:The front is a lever setup... youll get 10 inches, give or take a little, of lift with practically any bag.
