.53 is a huge difference to a pot hole or curb.
I'd still like to see pics if you have any. I have stock de-humped lowers and stock pie-cut uppers (with PP balljoints all around) and I had to step the lower balljoint 1.25" to be able to lay 22s (28.0" OD) with drop spindles. So if he's laying 24s (29.4") with drop spindles he would've had to step the lower balljoint almost 2" to be able to do that with stock arms. Now, I'm sure if you welded a big ass plate on the bottom of the stock arm and cut everything off the top of it that you could get away with not stepping the balljoint, but even then I'm thinking it sounds a little fishy.i dont have any pics of the arm, its just dehumped and plated on the bottom. top is pie cut. moog balljoints and tierod ends.
josh
So yeah... please get pics if you could. I want to see how this was done
Gotcha... I see what you're saying. I cut my spring pockets for RE8s but my opening isn't as big as it sounds like the ones on that truck is, so I still had issues with the arms hitting the bottom edges of the spring pockets (even though they're de-humped). Plus my upper cups are only 1.25" tall or something small like that so instead of almost having no upper cup or having to weld one in I decided to just step the lower balljoint. Granted, the arms now sit lower to the ground in relation to the center of the wheel, but that's not anything that would ever cause me any problemsthe front is cut for a re7, tie rods and the extra space needed for the arm to travel up. yea its 2" at the ball joint but its not at the point where it hits the frame. for 22's you gotta notch the frame a bit with stocks. its just barely more then you plate where you notched. you gain a ton of clearence when you eyebrow for a re7 so its just where it mounts to the frame really. you notch just like how you notch for a tierod. its not a wrong or right way. as long as its all plated back up its fine. arms will be built for it when it get bodyd. but thats just for more lift.
No nothing fishy lolSo nothing fishy now right man? LOL. I stepd arms on one bodyd on 22's and it sucked and hated the outcome.....
I just prefer to not have my spring pocket cut out as big as it sounds like you cut the ones on that truck. My pockets are plenty big as is being sized for RE8s
What exactly 'sucked' about the stepped arms that made you 'hate the outcome'?
love that truck, as soon as I get my rims in the next few weeks, I can lay the frame out, and determine what else on the suspension needs to be done, already notched the tie-rods on frame, i know ive done so much hahaha jk, I have completely wire-brushed frame down to bare metal to be painted!
