1 - 17 of 17 Posts
Gaaoooooo
They fit no problem if that is what you are asking yes, it is the stock size on xtreme and zq8 8" wide wheels. I have a set of 255's on the rear of my s10 if you are looking to go bigger, they also fit no problem.
Low in Alaska
i'm sayin a 245 would be a good size(245/50-16 is what came on some Camaros stock)...255 wouldn't be too bad, either..
235 seems kinda stretched to me..
Certified MASShole
i have a 235/75/15 on my 15x8s and they look a lil stretched i think with a smaller side wall they look better maybe a 235/255 combo
WHAAAh?
245/50's look the best IMHO
Lifted 2wd & Bodied 4x4
Bad94 said:
LOL 235's look perfect on on a 7"
maybe if you have a 70 series sidewall....I'm talking about lowpros here. With a 235 on an 8" wide rim, the tire will be about 1/4" wider than the rim so the tire would rub anything before the rim would. If you go any skinnier the rim will be wider than the tire and you will get that dreaded stretched sidewall look.
As for the 255 comment....255s are perfect for an 8.5" wide rim.
Gone Fisting!
I have the Sawblades, and the stock ones for 95' i was also wondering what size i should go i'm wanting to go for a 4/5 drop but dont want any rubbing issues.
Ahhhhhhhhh Satisfying!!!
245 50 16......gauranteed
I have a 4/4 on a blazer and have plenty of clearance with 245/50/16
1 - 17 of 17 Posts
