i have a 2/3 drop (spindles/blocks) on my blazer x. my stock tires/rims are 235-60-16. i plan on getting 20's.....probably 255-35-20's because they are the exact same overall diameter as stock.
my question is, what backspacing do i need? i have searched quite a bit on this forum and blazinlow, but haven't found the answer.
keep in mind that i might go lower in the future....therefore, i want to be sure that i can tuck the tires. right now, it looks like the fronts might hit the fender flares if i go much lower!
also, if i go to a wider tire in the back, how does that change the backspacing?
thanks, guys!
thanks, guys!
