1 - 15 of 15 Posts
i have a 94 chevy s-10 and i am wanting to put 20's on it, but i dont know how bad they will rub. my truck isext cab. and is lowered 4" all around i know the back wount have aby problems but i am woried that they will rub like crazy in the front, does anybody know how bad they will rub or if it is even possibe, i dont want to have to cut out the fenders! any info would be helpful thanks
Self Portrait
a 235/40-20 or a 270/35-20 won't rub the fenders any more than stock tires (guessing that your stock tires were in the neighborhood of 250/50-16.) But if you give me your stock tire size I can run the numbers for you.
my stock tires were a 205/75R-15 but i am now running a 4" drop with 235/55R-16 is that some better info for you to compare to.
amatuer porn star
you will need to get rid of the front fenders. maybe even some of the rear fender
4 inch drop on 20s ouch get ready for bent rims.
on the customers cars ive done you will have to get a 245 35 20 tire under there. the 255 35 20 rubs real bad. in rear wont matter. this is wiht a 4 inch drop in front. if your 235 55 16 which are a 26.1 inch tall tire dont rub then the 26.6 inch tall tire of a 245 35 20 will be fine but hte 255 35 20 is 27 inches tall will rub bad. but to let you know the tires will rub on big bumps up front on top of the fenderwells.
front rim size has to be 20x8 with 4.5 bs and the 245 35 20 tire
rear you can have 20x8 with 4.5 bs and 255 35 20 doesnt really matter
Discussion Starter #11
RawRedX said:
hey draggin, hope you dont mind me askin, but do you really 'drag sparks' ?
no man not yet, i just couldnt think of any other name, i will be dragginsparks one day i just want to get rims and body work done first.
GOT 20S?
ive got 20s on my bagged 95 blazer 255/35 tires and i had to remove fenderwells and so on but they ride great and dont rub now that fenderwells are gone
Discussion Starter #13
Hey i got my 20's last weel and they look sweet:thumbup: :thumbup: :thumbup: ; now i just have to save the money to bag it:cuss:
Discussion Starter #14
does any one know how much work has to be done to the front fenders to be able to lay frame with 20's: and a body drop???
GOT 20S?
I TOOK OUT MINE AND IT WASNT THAT HARD BUT IT WAS SOME WORK. YOU HAVE TO CUT THE AIR BOX AND SECTION THE FIREWALL OUT.NAD THE ABS ALSO NEEDS TO BE MOUNTED SOMEWHERE ELSE
HERE IS A PIC OF MINE BEFORE I CUT THE AIR BOX
I STILL NEED TO MOVE THE ABS
1 - 15 of 15 Posts
