Status
Not open for further replies.
1 - 20 of 28 Posts
Has anyone tried or put on the new Camaro SS wheels yet? I found a set for sale with tire and less than 100 miles on them. They are 5x120 bolt pattern, but no idea on offset or bs or even width. I tried to post a pic but can't for some reason, so here's the link, and if your interested you can shoot them an email. If you have a pic of your truck with them on it please pm me a pic.
http://stlouis.craigslist.org/pts/1280394996.html
MVP
From what I have read, camaro and corvette wheels fit right on a 4x4. Some 4x4 owners run a 2 inch spacer on the rear to push it out a little bit.
Saying that, I believe you would need to run a 2.5 spacer all the way around on you 2wd truck.
If i'm wrong please correct me!
BTW....those wheels would look ****** on a dime
Slap my meat on your pita
FireBall - Those were for the 4th gen wheels. I dont think anyone here has tried the 2010 wheels yet.
Iroc - Im sure if you goto GMs website and option out a Camaro it will tell you the width of them. Not sure where you are going to find the offset/bs.
DFWminis.com
S10 is 5x120.65
2010 Camaro
Bolt Pattern: 5x120
Offset Range: 35 to 45
Wheel Size Range: 20x8.0 to 22x9.5
I've got a set of 19" wheels from my wife's G8 that are the same bolt pattern/offset(38mm) as new Camaro wheels are. I need to dig them out of the barn and test fit them to see what kind of spacer I would need to run for them. The problem I'm finding is trying to find adapters from a 120mm bolt pattern to 4.75".
i wouldnt think so, cause they would only need bored out another.65 to match the s10 pattern........i was just asking!!! I will be going to my tire guy this next week to ask, cause i would love a set of these wheels powdered black for my jimmy!!!
hmmm...
yeah that would look pretty good
i just recall reading somewhere that boring out wheels runs the risk of failure. i could be wrong tho.
let me know what your tire guy says
Blue-X
you wont be able to bore out the wheel not safely, but for the rear you can have the axle shafts redrilled for 5x120
2010 Camaros and 2008-2009 G8's both have 5x120mm pattern. 67-02 Camaros all had 5x4.75" bolt pattern.
Float like a butterfly
you can not bore out your lug pattern safely,it will fail
FooldU
you can run a 5x120 no problem...we install them all the time at work. Some guys us E.T. lug nuts, but you usually dont even need those.
'00 Dime
1 - 20 of 28 Posts
Status
