1 - 10 of 10 Posts
I have a 2003 S10 ZR2 and I want to get info on a 2001 dual exhaust setup. Would It fit? Or would I have to do mods to make it fit?
Exhaust for a 2001 what? You can do single in dual out, dual in dual out, or take it to a shop.
I found a dual exhaust setup for an 01 s10 pickup truck but I have a 03 Zr2 . I’m looking to see if there’s a difference to run them or will they match up.
As long as the trucks are the same...single cab/ext cab, you should be ok. I'm guessing it's a cat back and not true dual exhaust?
Can't see why not...any differences should be minor if there are any at all.
You m might do some online shopping comparisons and see if one kit covers both years.
much less issues and or hassles, having your local exhaust shop do a dual exhaust install on your truck. couple hours of work, probably $250-450 depending on what you want, and brand of mufflers
1 - 10 of 10 Posts
