1 - 11 of 11 Posts
Does anyone know what the difference is in the 4.3 S10 @180hp,
ZR2 S10 @190hp and the one in the CK truck @ 200hp. The
compression in all are 9.2:1. Is the exhaust system the same?
Thanks,Gary
Project: Sabriel
the exhaust, and ive heard the cam, int eh full size is different. the ZR2 has a "high-output" engine.
All the fullsize trucks use a 3 inch exhaust system and a better set of manifolds. That IS the only difference and always has been. Since it uses a larger exhaust, larger exhaust lean a motor up slightly the comp will tune it slightly differently adding more fuel to compensate for the leanish running! Really just keeping the 14.7:1 ratio, so there is no different in tune and or cam!
There's clearance issues with the steering shaft, least on my 96 4x4 there was, the 2001 2 wheel ???? They are larger in inside diameter by 1/8th .Older full sized trucks also have a tri-y manifold very similar to a shorty header, those I havent tried or know someone who has.
Never Finished
Could you not port the manifolds on our trucks? Does anyone know the exact diameter of the manifold primaries, y-pipe, etc? If GM can get 20 hp out of that exhaust setup, that's what I'll do.
Well I guess then by going to a set of JBA"s it will pick the hp back up to 200. That should be a good start.
Project: Sabriel
i dont know anything about cams, its just what i heard...the HO engine had a hotter cam than the regular cam crane makes for the 4.3
Are the heads of the full size Truck 4.3's a better factory EX=Port?
What about the valves?
I would assume that the valve chamber's and pistons are the same if the ratio did not change!
Do the full size trucks use Vortec intakes?
1 - 11 of 11 Posts
