Hey Guys i noticed some engine oil leaking at the back of the motor. Ive noticed the oul dripping down and leaking in different spots on the floor. Its a 4.3 gm motor. Just wondering what the issue could be and will it be an expensive repair?
Since it's the back of the motor, crawl up in there and take a look at your oil pressure sender and associated brass fitting. Drivers side of the distributor.
That's hard to say w/o seeing it since they are so close. I'd pull the valve cover first since it's easy to get to and you can see the oil sender better with the valve cover off.
