2000 s10 2wd 2.2
So first a little background; instrument cluster stopped working and transmission began to have shifting problems. Stuck in higher gear. It was throwing a bunch of codes to the transmission solenoids. Found blown fuse to cluster. Replaced fuse and it blew again. Found 2 broken wires in harness going to ecm. Fixed that now I have instrument panel working except prndl and odometer. They come on between lock and run but go off in run. No codes now for transmission but still not shifting. Any help would be appreciated.
