I have a 2000 s10 2.2 auto ext cab. I'm getting 14 mpg on the highway:rant:..I have changed the cat,plugs,plugwires,temp sensor, flushed, checked vacuums, I'm going to reinstall my factory air box (I have a k&n cold air now) and fuel filter. Also when I am at highway speeds sometimes its like I take my foot off the gas and it will drop 10-15 MPH...I'm at my witts end..any ideas?
Thanks ahead for any help
If it slows down quickly check your brakes. Maybe something sticking on these trucks aren't all that easy on gas either. Any codes in it ? If you can get your hands on a scan tool that would be a good place to start
Thanks for the reply, Its throwing no codes. Only code it threw before was a temp sensor which I replaced. Wheels seem to turn free. I know I shouldn't get great but I should get more than 14 on the hwy...I get about 35 miles on 1/8 of a tank it has the 19 gallon tank
It's mostly BS
Tell us that's not how you are calculating your fuel efficiency. In case you are, try it this way:
http://www.fueleconomy.gov/mpg/MPG.do?action=calcMPG
I fill up, then I drive until 1/2 until almost empty. I fill up again just as before I take the miles and divide it by the gallons
