1 - 13 of 13 Posts
This is a buick century.
the GM paint had failed, and the lady has been driving it around looking like a real POS.
I dont like to do stock repairs, nor repaints, but, this belongs to a good friend's mom.
This paint was so trashed we didn't know it was covered in hail damage.
After stripping the top surfaces and repairing hundreds of dents, it was primered, blocked, primered again, and blocked again.
Currently wetsanding, will post finished pics in a day or two.
The front window was oriingal, had some chips and was a brownish burned tint, so i had windshield replaced, and will be getting the tint removed/reinstalled as well.
It's not perfect, but then again it is a buick century..
Car Automotive parking light Automotive side marker light Wheel Tire
White Light Black Textile Sleeve
Automotive parking light Wheel Tire Automotive side marker light Vehicle
Car Vehicle Hood Motor vehicle Automotive lighting
Vehicle Land vehicle Car Grille Motor vehicle
finished buffing, gave it a quick wash, installed the headlights and taillights, and will clean it up more tomorrow.
both front window regulators are dead, so ill be pulling the door panels off to see what it needs as well...
Automotive parking light Automotive side marker light Wheel Tire Car
Hood Luggage and bags Sleeve Automotive lighting Bag
· Premium Member
mmm, orange peel.
GM never charged extra for it!
So this clear problem seems pretty common with GM vehicles of those era. Is this a problem with the quality of paint or was it a paint process problem? My '00 Z71 clear started coming off in lines and I could spot many many Silverados the same way. My '04 Accord also had clear problems like this.
· B4U Task Force
My guess is it's a cook in the desert sun problem.
Discussion Starter · #10 ·
From what I've been told, it had primarily to do with a change in the composition of the primers they used and also the era during which the major shift to base-coat/clear-coat took place, and this new paint didn't have the ability to 'move' with the surfaces. The manufacturers had to switch to low VOC (volatile organic compound) paint to meet EPA regs. most went to a basecoat clearcoat system. However, they were really just learning about the vagaries of this system. early paints needed 45 minutes drying time before the clearcoat was applied. When the factories needed more product, they didn't wait as long as they needed to, so the paint wasn't truly dry. this caused adhesion problems as the paint aged. Where before it was more flexible and wouldn't crack it now is not flexible and does crack. The sun hits the upper portion of the car. The paint and the body panels have different coefficients of thermal expansion. If the paint cannot flex and move around with the body then eventually, you'll have a similar problem. Then you take said car out and drive it down the road at 70mph. The wind will impact the leading edges...along with bugs, rocks, birds... so you will have some peeling there first.
View attachment 366758 View attachment 366759 View attachment 366761
Very Nice $5-$10k(retail) surprise gift !
1 - 13 of 13 Posts
