Cheezeit9
How do I check to see if I have just front wheel ABS or 4 wheel ABS on my 1995 2wd S-10? What is the RPO code or any othe way to find out?
Shi just unhook it bro
There is only rear wheel ABS (RWAL) and four wheel (4WAL). I'm not sure what the RPO code is, but you can just check if there are speed sensors on the front.
If you've ever changed or removed your rotors did you have a wire running to a sensor behind the rotor? You should be able to see the wire by just looking at the back side of the rotor while the truck is jacked up. If you do you have 4 wheel abs.
My truck has four wheel.
