Using a 2" carb spacer, will the trans. kickdown cable and throttle cable hook up alright? I use to have a 1" throttle body spacer and it all worked good. I now have a holley 600 carb, edelbrock performer intake, 700r4 tranny bolted to a '99 4.3l, and a 3" body lift. I thought I would get a better answer in the v8 forum.
I've been told that it won't, but I guess a good question is where is the bracketry located. You can buy a bracket that slides under your carb or TBI unit and will allow you too run a large spacer. If yours is similar then it should be fine. Otherwise if the bracketry is connected to the engine, you may have issues.
