1 - 10 of 10 Posts
Registered Loser
I know I keep coming up with a million different ideas for my truck...but hey, I'm just expirementing. Anyways, if I did a 2" BL and trimmed the fenders up a bit and got wheel spacers(if need, not sure of the offset of the wheels that i want)? A 3" is a lil too big..unless I got a step bar for the side....hmm....anyone? Thanks...late...
It will fit better with near stock backspacing on your wheels, but 32s are gonna require trimming.
Project: Sabriel
id think the problem with 32's would be more rubbing on the frame, least if the tire is an aggressive one.
my 32's only rub on the frame, i'm running the stock alloy 4x4 rims with mud king 32x11.5 tires, i have a 3" body lift, aal, and torsion bar crank. they do rub on the frame a bit when turning hard, i'm thinking about puting on some 1/4" spacers. i also have a superlift 2" that i need to install, i don't think it will rub the fenders at all after the 2" lift is installed. you should be ok running 32's with a 2" body lift, t-bar crank, rear aal, and minor fender trimming
its AAL & it stands for add-a-leaf ;)
1 - 10 of 10 Posts
