I saw somewhere i think in lmc truck's catalog that the 2.8l and 4.3l use the same starter I have a 2.8l one here that is practically brand new and one outta my jimmy that is getting weak will they fit or are they to different i see a few little things but i'm not sure if they will still work.
i saw what you did there!
bolt pattern same?
both engines use same size flexplate?
if so then it should work if you can connect the wires etc
all depends on the above things
i wouldnt think they would interchange but im not sure
id like to know how it goes
all the 2.8 and 3.1 and such starter noses ive ever seen are straight across bolt pattern, unlike 4.3 and most v-8
well guys a 2.8l starter does work on a 4.3 bolts right up and cranks it over no noises or anything no shims nothing wires hook up now i just gotta put the inspection plate back on
