You need to start by reading everything in the V8 Discussion forum. It will have 99% of your questions answered.
Moved to V8 Discussion.
Where is the V8 discussion?You need to start by reading everything in the V8 Discussion forum. It will have 99% of your questions answered.
No disrespect but I have been going on trying to "read" everything in the V8 Discussion forum but alot of those are people with different size motors than mine, different swaps, I have not yet seen 1 post talking about an LT1 swap, I am not able to find anything specific to go from a 2.8l to LT1 let alone a 350, now I know im new on the site but im pretty sure I can work my way around a computer, unless I am doing something wrong, please direct me to a discussion of 2.8l to LT1 swapI moved your thread to it. Click on V8 Discussion just below the banner.
Sorry if I hurt you in anyway, I am inexperienced with doing a swap of any kind, all I was looking for was for some help on what correct parts to locate. I did not think I would be starting a discussion just to plainly be told, to figure it out because someone else may have already started that discussion. That I am unable to locate or find the correct or best suited to my project. I was excited about joining a forum on something I wanted to better my self in but you absolutely just ruined this experience for me. Thanks for nothingIt doesn't matter if it's a 2.8 to begin with. All of the sbc's are the same size and install the same.
Oh...and just so you know...the report about me that you sent to Admin...surprise....that's me.Sorry if I hurt you in anyway, I am inexperienced with doing a swap of any kind, all I was looking for was for some help on what correct parts to locate. I did not think I would be starting a discussion just to plainly be told, to figure it out because someone else may have already started that discussion. That I am unable to locate or find the correct or best suited to my project. I was excited about joining a forum on something I wanted to better my self in but you absolutely just ruined this experience for me. Thanks for nothing
An LT1/SBC is the most common swaps ever done on an s10 since about 1984. We can all provide a wealth of knowledge, but it does get repetitive every week explaining you need swap headers, s10 oil pan, notch the cross member, recess the radiator, shorten your driveshaft, modify the trans cross member, and then figure out the wiring.I have a 1993 S10......... 1996 Z28 Camaro LT1 with 5 speed
BS statement of the day right here.Almost everyone in here daily drives a V8 swapped s10.
I found and ordered the trans dept mounts already, some people say you notch the frame others say you dont that's why I ask for help, the transmission as well I just want to know if anyone can help identify if my 93 s10 2.8l has a t5 attached to it. My understanding I would have to switch the tail end on my camaro transmission. But idk if my s10 has a t5 so I'm still trying to figure that out. Nor did I know about the oil pan and I would assume pickup tube, also I am working with what I got if I could get a ls I may have done it but as of now just wanting to make something out of my camaro.An LT1/SBC is the most common swaps ever done on an s10 since about 1984. We can all provide a wealth of knowledge, but it does get repetitive every week explaining you need swap headers, s10 oil pan, notch the cross member, recess the radiator, shorten your driveshaft, modify the trans cross member, and then figure out the wiring.
Then again, a 1996 LT1 in my opinion should be left in the 90s. 25 year old wiring is fragile, and I would suggest an aftermarket harness/computer set up such as the one holley makes.
Almost everyone in here daily drives a V8 swapped s10. We can all help. But, literally pull your LT1 and trans, take your s10 apart and start putting them together. From there, it’s all very basic.
I think TRANSADAPT makes a S10 Swap-In-A-Box that has dang near everything needed to drop a SBC into an S series.
But, if it were me, having a few SBC S10s in the past, the LS platform is vastly better in nearly every way for a swap that you can enjoy everywhere, every day, every time.
