Hey guys I have a 1984 1st Gen Blazer 2wd and I swapped out the old 2.8 for a low mileage 2002 blazer complete drivetrain that is now installed, I used the complete harness the engine turns over but cannot get it to run.. getting fuel but no spark and the gauge cluster security light stays on ,not sure if I have the correct wires connected.....need some help on what wires should be connected.
not really sure. you may need to turn off the security in the pcm. I dont suppose you have one of the gm tech tool programers?
time to get cereal
Do you have the BCM and the 2002 ignition switch? You'll need those for it to run. You have to have the whole passlock system intact.
