I've got an 83 with the 2.8 v6 that I want to swap to a 350 small block. I've got the engine. A 350 4 bolt main.
I've been digging in the forums and can't find any thing so I'm asking here.
What all parts do I need for the swap other than the engine?
· Been there Done it
4 bolt mains means it's most likely out of a C/K3500 1 ton truck or van. What year is it? Casting numbers on the heads and block?
Since you have an 83 there is a good book that gives you step by step how to. It's dated material, but so is your truck and engine so it is just what you want.
Reactions: Boshears
That I don't know I'm going to look at the engine probably Friday.
I know summit sells a swap kit for this type of thing but my question is will the trans from the 2.8 work on a 350? The pan in my truck matches a 700r4 so I was wondering if I could swap the bellhousing and use the same trans?
No, they are different in more ways than just the bellhousing. Gotta have a 90° 700R4. One from an 89-91 V8 truck or van would be the best choice. The last few years they were made were relatively strong units. Use a 4.3L torque converter since those will have a slightly higher stall speed behind a V8.
The 83 700R4's are pretty weak would be toast behind a V8 if you could get it to work. later versions had an auxiliary valve body and other improvements.
