what sensor is this in the circle? and what tube is that where the arrow points. I can't figure out what they are. I have a problem:
I have a 1991 S10 2.8 5-speed and it has 32,060 orginial miles on it. No joke. It's just never driven a lot. All that I have done to the engine is install a throttle body spacer and stainless steel braided fuel lines. I was having this problem before I did any engine mods. When I'm exiting off the high way going about 60 mph in 5th gear, I push in my clutch to down shift or coast and the engine dies. Right when I hit the clutch in. I coast with the clutch in and start the engine back up while exiting and its fine. Why does it die? It happens every time I drive and its making me mad cause I don't know how to fix it. Happens in 4th gear too. I checked all the vacuum tubes and connections. I have a new clutch. Checked the tranny and clutch fluids. What could be wrong?
I need to fix this... but I'm not going to pay $$$ to the dealership to fix it. -Cause they'll just pick something and replace it. I haven't had luck with my local chevy dealership. If you have or had this problem or heard about it, please let me know. Thanks...
