V8 needin' member
i have a 85 s10 with a carb'd 2.8 in it and the problem is i idle high.... liek 2300 most of the time...could anybody tell me what is goin on i tried to adjsut my carb and that didnt help
What you have is a vacuum leak. Knowing the amount of vacuum lines that are on an old S-10 2.8, it is a safe bet one of them is leaking. If not all of them.
V8 needin' member
so what u r telling me is that i am ****ed as far as finding the leak or is there a way to isolate it... it idles real high(2200) for a while then occassionallly after a while itll drop down to about 1000 which is ok?:werd:
yor chocke may be sticking also but its pretty easy to find a vacum leake
. but its moer then likely that old pos choke
i once had the same problem
.to find vacume leak get spray bottle fill with soapy water spray on one line at a time . if you see no air bubbles its not that line try the next
V8 needin' member
ok cooll thanks man yeah like i sprayed the carb down with carb cleaner a while ago and it stopped doin it so im thinkin it might be the choke.... im gonna check those hoses too
thanks
russ
V8 needin' member
damn it keeps getting worse im idling around 2600rpm now... i checked my lines and found one that was torn so i replaced it and it still didnt fix it...still need to check the choke out
