61 - 67 of 67 Posts
This... I would like to see.
I will have to look at the supercharger and see how it is mounted.
Never heard this before.
If you still have the FB contact, ask for pix or it never happened...
He said it goes in place of the AC compressor(mine doesn't work anyway), it's the Aisin SC14, I've been meaning to ask for pics just so I can see how he's got the tubing and IC mounted
88 S10 Durango Long Bed 2wd 2.8L Auto
Waiting on pics of the aisin supercharger but here's one of a ford thunderbird SC on a 2.8, I'm curious how hard that one is
time to get cereal
The thing is that with all the work to do that you could just adapt a later FWD engine into the truck instead and probably make more power NA. Personally, I would figure out how to shoehorn an LZ9 into the truck, it has 240hp and 240lb/ft. with a very wide powerband. 90% of the torque is available from 1500 rpm to 5500 rpm.
That and it weighs less than the old 2.8L
With the thunder chicken SC I agree the Toyota one is sposed to be a plug n play blow thur set up just add fuel (something about full size gm) and Retard spark accordingly, though I was going to look into a timing controler, the trick with the sc14 is it's got a magnetic clutch so you can turn it on and off, itd be nice to be able to flip a switch for extra power and just as easily go back to mpgs
Boozebag
Discussion Starter #65
Sounds like Mad Max to me... Ha
The Ford interceptor in the movie had a magnetic clutch on the supercharger.
I have a 1987 Nissan D21 Hardbody with a Ford Thunder chicken turbo 2.3 in it. It's also a 5 speed.
Surprises a lot of people...
the new guy
that little 2.3 boosted is fun. my buddy has a thunderbird sc and one of the autocross guys had the mustang with the 2.3 sc.
Ill probably end up going turbo just due to not being able to find a sc14 even though id rather have the option to choose between power and mpgs
61 - 67 of 67 Posts
