'93 Sonoma reg. cab Duke Engine. I want to drop it 2 inches in the front and 3 in the back. Drop Spindles in the front and McGaughy 3 inch leaf springs in the rear. With this drop what potential problems will encounter? I plan on getting new shock anyway so that is not a concern. Will I have pion angle problems? Driveshaft problems? excessive vibration? Camber and/or toe problems? What I want to know is with the a drop this small is the job relatively painless and easy, or will it cause a lot of other little things that will go wrong due to the drop.
s-series #2?
zero problems if you dont skip steps. you will need shorter shocks in the rear with that setup though
