I know these questions have been asked time and time again, but mine does vary slightly. I have a '87 s-10 that is long wheel base, and i want to do a 2/3 drop on. Because its long wheel base will that make any difference on dropping it? BTW: I plan on using spindels and blocks, and if everything I have read is correct I need 2 inch spindles for the front, and a 3 inch block in the back, correct me if I am wrong.
-Dave Hogsett-
Long Bed Member
yea 2" spindles and 3" blocks will be fine. as for the dropping a long wheelbase truck you shouldnt have any probs with that it im assuming by long wheelbase you either have a long bed like me or a ext. cab and both are dropped as easily as a shortbed s10
ment to say that i was going to use angled blocks, but thanks for your help. It will be about a month before i get it dropped but i will let you all know how it works out.
