I have found a 2.2L stroker kit for a 2.2L S-10. It's supposed to boost your horsepower from a stock 118 to a 145 and torqu from 135 to 160. It's at dragevelution.com and I've tried to order it but I can't get through. I some one could help it would be appreciated. If I can't order it I'll probably put a motor out of a Z28 in it.
Thanx,
-Druski-
The Sex Toy
im imterested also
that place has been mentioned in the 2.2L section and they are sh*t. guy almost lost $2000 with em, they never shipped out his products or somethin......it is in the 2.2L section labeled "cams for 2.2"
Guys, come on now a 2.4L DOHC GM engine in a cavalier is only putting out 150 to the flywheel. For the money that you spend on geting the stroker kit and having the machining work done, you might as well have swapped the engine, or put a turbo on it.
Registered Abuser
I would recommend staying away from drag evo...unless you live near them and can buy the parts over the counter...
It's ill advice to buy from them via internet or over the phone.
Been there done that:tony:
