Premium Member
I have a 2000 2.2L. The timing chain broke while on the highway. I took it apart replaced the timing chain, gears and tensioner. The was alot of debris in the pan. I cleaned as much of it as I could. I started the engine and all was fine. I went for a ride. It ran great then while on the highway it lost power, I got off and headed home, just before I got back it lost all oil pressure.
Do you think the pick up for the oil pump is clogged? Truck has 200,000+ miles on it.
Premium Member
did the motor lock up cuz based on what you said that should've happened or could the o/press sensor failed and shut down power
Premium Member
It did not lock up. I went out about 30 minutes ago and started it up. It had low oil pressure where as before it had zero.
