1 - 2 of 2 Posts
Had to pull the motor out again because it needs sleeved before it goes to the dyno. The trans has been making a knocking noise for a long time and only does it over partial throttle. If your 3/4 to full or completely off the gas then it doesn't make the noise. The input shaft seems to have a good bit of side to side play and when we put the tranny in the first time it was severely hard and had to be bolted to get it in. I was thinking maybe piolet bushing bc I did a manual swap and didn't change the pilot bushing. But the trans seems shot.
349654
You said you did a manual swap, was the engine previously bolted up to an automatic transmission?
They don't use a pilot bearing on auto's, so if you didn't add one, then you are simply missing one, which would cause some troubles.
1 - 2 of 2 Posts
