The exhaust manifold on my truck has a few holes in it. I have always heard that they are notorious for cracking/developing holes. I am going to have it replaced soon. Is there a stock style manifold out there that is of better quality or is this just a weak point that will have to be replaced every so often?
Moved to Exhaust.
Since you haven't gotten any responses to your question, I'll move this to the 2.2L 2nd Gen 4 Banging forum..
Boozebag
Cost wise, a stainless header is a good bet and is a direct bolt in. You might see a little improvement in performance.
The iron manifolds I have seen are not cheap and they may have the same issues as the original.
I have installed 2 stainless header replacements and they have posed no problems and are still running.
They are also more attractive than the lump of iron called a manifold.
They are also easy to install with common tools.
Just a suggestion.
Discussion Starter #8
Just a suggestion.
I didn't consider stainless. I will include that in my search. Thank you.
